Uudet etukajarit lepakkokatteeseen.
Tervis03100
Viesti Kirjoittaja Tervis03100 »
Moro. Olis tarkoitus vaihtaa uudet ns marine soveltuvat etukaiuttimet tollaseen vm 08 ultra classic electra gliden lepakkokatteeseen mut kun ei ole tarkkaa tietoa mikä on se orkkis koko noissa kajareissa. On 5.2 /6.00/ 6.5 /7.00 tuumaa noi vaihtoehdot ite veikkaan et olis toi 6.5 mut sillähän se selviäis kun irroittais ton katteen mutku ei viittis turhaan edestakaisin ruuvata auki ja taas kiinni. Et jos jollakin olis tietoa oikeesta koosta että sopis uudet vanhoihin reikiin niin olisin kovastikkin kiitollinen :)
Pekka L
Re: Uudet etukajarit lepakkokatteeseen.
Viesti Kirjoittaja Pekka L »
Eipä oo tullut mittailtua, mutta google kertoo näin:
The front speakers in a Harley Davidson Electra Glide are typically 5.25 inches (5 1/4"). Some models and aftermarket options may accommodate 6.5" speakers with the use of an adapter or by modifying the speaker housing.
Details:
Stock Size:
The standard front speaker size for many Electra Glide models, including the 99 Electra Glide Classic, is 5.25 inches.
Aftermarket Options:
Many riders choose to upgrade to 6.5-inch speakers for improved sound quality and volume.
Adapters:
If you want to install 6.5" speakers in a fairing designed for 5.25" speakers, you'll likely need an adapter.
Modifications:
In some cases, minor modifications to the speaker opening or mounting points may be necessary for larger speakers.
Specific Models:
Some models, like the 2014 Electra Glide, may have slightly different speaker sizes or require specific speaker types for optimal performance.
When choosing new speakers, consider:
Power Handling: Ensure the speakers can handle the power output of your motorcycle's audio system.
Sound Quality: Read reviews and compare different brands and models to find speakers that meet your audio preferences.
Ease of Installation: Consider whether you'll need adapters or modifications for installation.
Pekka äL
Satulapummi Wakka-Hämeestä
Tervis03100
Kiitti toi jo vähän jeesas. Nyt luvataan tänne etelään ja pk seudulle vähän kosteempaa keliä niin vois pitää sellanen tallipäivä ja ruuvais ton katteen etuosan vex niin sitten näkis mitä siellä on vai onko mitään kun radio, cd ja usb ei kuulu mitään vaik kaikki näyttäis muuten toimivan. Vähän sellanen kutku et onko siellä kajareita ollenkaan mut se selvii sitten. Mut joo tos oli hyvää infoo kiitti.👍😀
